121 - 126 of 126 Posts
If you want the 2wd 4wd display lights to work and if you ever want to remove your KEBC actuator get the combo kit, if not just get the manual actuator kit
Brake Actuator Problems
2008 Brute Force 650, removed actuator cleaned, tested with battery to be sure it turns and it does, check ohm reading and the are in line. When the switch is turned off, continues to hum and will run battery down. You can switch on and off a few time and it will stop or sometime you can tap actuator and it will stop. Anyone know how to fix this or what is causing it?
When i test my 4x4 switch, I have .09 v, when it should be 0...
It's like i have power bleeding thru my ground somehow...
Thought it might be a bad diode in my regulator/ rectifier, but still there when I unplug the rectifier....
4wd is blinking on dash in 1 second intervals, or .05 seconds each...actuator tests good, works when hitting it with power on bench...
To me It is not killing all of the poWer, so it will not switch to 4x4. ....
Any ideas??
I've got. .6 volts coming from my cdi green wire middle plug and .6 volts at the switch when I flip it to 4 wd. Any ideas? I've changed cdi boxes and same problem. I see u guys say that it should be 4.7 volts. I checked actuator and it worked. I have no 4 wd and its not flashing back and forth. Speedo works. Any ideas?
Seems dirtydog had the same problem...wonder if he ever figured it out...
I have an 02 Prairie 650
4x4 works, all the time, switching to 2wd causes the 2wd/4wd to flash and 4wd stays engaged.
Getting pretty bad popping coming from the front end while 4WD is locked in. It only does it under load. The quad was mudded some by previous owner. I know hardly anything about these machines so any help would be appreciated. I’d rather try to fix it myself and learn about the machine than pay someone else to do it. Thanks Folks
