hey jmeier1981 did you end up getting your machine fixed at the dealer? if so how much?I hope for your case its not the same thing that happened to mine when it sounded like that.
The guys here are great and should be able to help you trouble shoot your noise it could be the clutch itself or the bottom end like mine was, just hope for the clutch to be the culpret its a MUCH cheaper fix
.......:thinking:.....Where did he go???? ....We just wanna help:haha:What year is your brute chine?
How long have you owned it?
Did the noise just start or have you been hearing it for awhile?
Does it do it in gear or neutral....or both?
Have you slipped the belt recently?
Has it every been sunk in water?
The clutches are noisy on these Vtwins even when there new but you may have something else going on. Give us a little more info on what you got and what its doing.
I would just to be safewhat about if its fuel injected?
