1 - 7 of 7 Posts
SAY I WON'T!!!
Not sure about those spring spacers, but I know Gorilla sells some spring spacers that are billet aluminum. The Gorillas are alot more pricey than those...
yous hockey pucks did that on my ford lol
yep those springs spacers are like gorillas except theirs are made of metal.
The material he is using looks better that the PVC people are using at home.
Personally I'd be scared of PVC. You could do a pipe lift. Same concept you just use a 2 or 2.5" piece of steel pipe as the spacer and from that the "pipe lift" was born.
^ yep. I'd build my own first.
SAY I WON'T!!!
I had the Stage 1 Gorilla spacer lift I bought from Superbogger750, but I already sold it someone a little while back. He has an 08 and says it rides super rough, even with the softer 08 springs. FYI
probably from the reduced travel the spacers take up
1 - 7 of 7 Posts
