1 - 15 of 15 Posts
I just bought a 2013 XMR1000 and have been looking and looking for something I can do to it. I want to start with an exhaust. Does anyone know what I can use? I'd really like dual exhaust, but a nice slip on would work too.
if you want duals you have either looney tuned or muzzy super pro, however in a single the ron woods is awesome sounds great and from what ive seen and heard make more power than the LTE not sure about the muzzy though im a huge fan of muzzy and would probably be my personal pick
Any ideas on where I can find one? Ive looked and looked and havent found anything for the 13 XMR. There are plenty for the 12 Outlander 1000, but no XMR.
+1 for VFJ he hooked me up, I have muzzy duals on my gade
My buddy just put a hmf slip on, on his outlander an it sounds awesome no noticable power gain but if your tryin to go easy on the wallet get the hmf sounds like a harley!
Does anyone know if a slip on exhaust off a 2012 Outlander 1000XT will fit my XMR?
Just a heads up to all who have a 2013 XMR. The Big Gun Slip on exhaust off a 2012 Outlander 1000 WILL fit. Perfectly!!!
You will not be able to get a full Muzzy system for your XMR as it is based on the Max chassis. The Muzzy system isn't long enough for the extra length of the Outty. You will have to use a slip if you go with a Muzzy. Having a 1000 Max with both the Muzzy pipe and tuner, it is a very nice pair for both power and sound. Not overwhelmingly loud and no droning while cruising at constant speeds.
vforcejohn is the person to deal with and will get you hooked up.
performance atv has an xmr snorkel riser kit and it looks clean!! just an idea
Discussion Starter #12
Might need the riser kit since my new XMR sank to the bottom of a nasty hole this weekend. WAY to deep for that ol thing
Discussion Starter #14
Actually, not too bad. Drug it out, winched it into a tree, drained what I could, towed it home, drained everything, let everything dry out, ran diesel through it, flushed 12 qts of oil through it, changed oil filter, added fresh oil, and there we go. Back to the trails I went for another 2 days. Its in the shop now because the air compressor sucked in some muddy water. Warranty covered it.
Good to hear, glad it worked out for ya.. I dread the day I swamp mine :( but as addicted to the deep stuff I have become it's only a matter of time
1 - 15 of 15 Posts
