What brand oil do you use?
  • Amsoil
    Votes: 59 11.1%
  • Bel-Ray
    Votes: 9 1.7%
  • Castrol
    Votes: 72 13.6%
  • Havoline
    Votes: 5 0.9%
  • Lucas
    Votes: 8 1.5%
  • Mobile-1
    Votes: 76 14.3%
  • Pennzoil
    Votes: 14 2.6%
  • Quaker State
    Votes: 2 0.4%
  • Royal Purple
    Votes: 37 7.0%
  • Shell Rotella
    Votes: 81 15.3%
  • Torco
    Votes: 2 0.4%
  • Valvoline
    Votes: 44 8.3%
  • Manufacturer brand
    Votes: 105 19.8%
  • Cheap Store Brand
    Votes: 12 2.3%
  • Maxima
    Votes: 4 0.8%
  • Total voters
    530
1 - 20 of 212 Posts
Got a booklet coming with a comparison of many ATV oils. Will be an interesting read. Before it gets here, I would like to poll what brand you all are using. Then see how these compare and rate when i receive the report.
I've used other but right now I've been using Kawasaki oil. In this month's quad magazine there was a new oil that is supposed to help prevent and/or protect against moisture build up or water in your oil. Anybody heard of it or used it? I'll look this evening at my magazine to see if I can find the name of it.
I use Kawasaki oil. When I need to flush the water out of the crank case I use Havoline until it's clear then go back to the Kawi oil.
I use Kawie oil or Valvoline atv oil....
Amsoil for motorcycle's. I chang it onece a year.
i've been using lucas 10w40sae motorcycle oil but on my next change i'll hopefully switch to torco, given it's not too crazy priced compared to lucas(8$/qt.)
this would be it, sir. I want to see how it rates.
http://www.motorcycle-superstore.com/ProductImages/OG/2007_Bel-Ray_ATV_Trail_Motor_Oil_with_Rust_Defense_--.jpg
Yep thats it, I'm interested to see how it rates as well.
I use Kawasaki oil in mine
I use Valvoline ATV 10w40 (picked Havoline on your list cause thought it might be a typo)
I've heard about something called mystery oil if you sink your bike flush with this stuff.. think it was on a moto x site.. any body esle heard or used it??
Yea a few to many times.:thinking: It works great.
Marvel mystery oil. It's in a red bottle and works pretty much like sea foam.
Discussion Starter #15
i use seafoam when the need arises. so far it's only happened twice. :)
I use the Valvoline Four Stroke 10w40. So far, I have not had any problems with it, and I do a complete service every 50 hours. I also use the Fram filter.
bel-ray...around $8.00 a quart
Discussion Starter #18
Where do you get the bel-ray oil, mattg?
:eek: I service mine every 15 hrs. :eek:But I go more by the oil viscosity than the hour meter !! Run castrol Syntec 10 w 40 Fram filter
1 - 20 of 212 Posts
