while tryin to pull one of axles out, the shaft popped outta the inner joint. upon inspection of the end of the shaft, a part of the end of the shaft after the snap ring broke off. im guessin thats why the shaft actually came out, the shaft broke and the snap ring let go cause the snap ring is still inside the joint. any ideas on how to get the joint out of the front diff?
