1 - 20 of 32 Posts
Ok... just back from 5 days of riding in BFE Idaho.
A couple of observations;
1.) These stock Dunlops aren't much. They drift great on gravel roads, but not much in the traction dept.
2.) They must not be too thick, as I ran a stick thru one of my rear tires, could've been a rock, but I think it was a stick. Either way, I'm not impressed.
So..
I already knew I was going to upgrade the skinz.. probably go with a 26" on aftermarket 12's.
I am seriously considering the Terracross and one other... (slips my mind right now) But I want to make sure that whatever tires I get have some good strong belts in them... I hate fixing a flat on a trail ride..
What do the dedicated mountain/trail riders recommend?
Stock tires on quads are garbage, and the brutes dunlops are on the top of that pile of garbage lol.
If you are seriously concerned about flats, you could go with an 8 ply tire but they seem to be heavier. Remember the dunlops you have are 2 ply, almost all aftermarket are 6 ply, and there are some 8. Honestly I would say you would be fine with a 6 ply unless your going into really bad situations for tires often.
With that being said if you do go with 6, you have pretty much any option you want in tires as they are the biggest available. As far as helping you pick that tire, wed need more information on what you regularly drive, if you hit the odd mud hole and need a somewhat aggressive trail tire or not.
Teracross tires seem to have been doing well from what ive been reading and heard so it might be just what your looking for. But if you do rock crawling and stuff something like a big horn might be better.
GBC Grim Reapers. 8-ply radial, superier in every way to all others I ever ran. TerraCross are also a great tire.. a 6-ply but a bit more bi-directional. Don't trust the Dunlops into the wilderness...they are just a 2-ply and will leave you walking...Oh...you just found that out...:)
Ya know... I looked all over that stinkin tire for a ply rating & couldn't find it.. 2-ply??? Holy crap.. no wonder! LOL!
The Big Horn was the other tire I was looking at..
I use this machine daily at my home; just basic pasture & some dirt, snow in the winter.
I also use it at my place up north out of Sandpoint.. lots of sticks/rocks/mud/snow/dirt.
I won't be lifting it, and don't want giant tires.. no need for 'em as unlike many of you, I use it as an ATV, not a submarine..:biggrin:
I do plan on going up one size, and I'll probably go with aftermarket wheels, but'll stick with the 12".
so; dirt, gravel roads, broken rocky stuff, muddy sections, ..... basic trail riding stuff..
I just looked at the Pit Bull Growlers, but they are directional.. I think more of a multi-directional tire would be better..
What's funny, is I've owned my 02 Rancher since new, and have had great luck with the OE Goodyears... so much so that I've stuck with them. 8100 miles & I'm on my third set of rears and my second set of fronts.. only two flats in 10 years. Same trails, same usage..
hmm you want to do just about everything with them don't you? lol. I would say grim reapers or big horn as stated before(Not a fan of ITP tires in general). Unless you want something with a little more bite like a zilla, they would help with the mud and snow but would be worse for rocks.
If it were me tho, Id go with a 27". Just gives you a little bit more ground clearance without making to up high and unstable. In saying that as well tho, take in mind most tires don't measure true to so size. so if you got 26"s that may measure 25", or it may even measure 27". What ever tire you pick, make sure you research it runs short or tall.
Understood.. I'm shying away from the taller stuff for two reasons;
1.) I'm addicted to the power.. and I know the larger tire I spoon on, the more it affects that.. heck.. going from a 2 ply to a 6 ply by itself is going to add some resistance..
2.) I like how stable it is in corners (read; sliding on gravel roads) now.. I don't want to make it more apt to high side my fat butt off..
I like the looks of the Zilla, but I really think that'd be overkill for my application.. the T-cross, Reaper, or the Big Horn look to be some of the best choices..
remember with aftermarket wheels your going to be wider, so your going to gain some stability from that too.
As far as power loss, 26-27 isn't going to make a big difference, talking 2-3 pounds for each tire on average. You can compare the weights here: MudInMyBlood Forums Tire Weight Chart
If your wanting an absolute stock feeling with even more stability though id choose the grim reapers.
A buddy has 28" bighorns on his popo, great tires on the trails, and even hold their on in mild mud.
My 589s seem to be a good agressive all around tire. They are exceptional in the snow and mud for what I do. Im a trail rider 90% and plow the yard in winter.
I just did about a years worth of research and went with the 25.5 pitbull growlers on aftermarket 12" rims. I googled every thing imaginable on every tire in the trail category. Looked at many different sites, looked at in depth reviews on Jacobs atv and other sites. And that is what I decided was my best choice. Good luck, it's a tough decision.
BTW, while the treads blocks are arranged in a directional manner, the tread blocks themselves have many different biting edges and shapes.
I have big horns on my brute i really like em. I ride in sand, mud, trails and also a fair amount of snow. They climb rocks well and do really awsome in the snow. I really have been fairly impressed in the mud but i know they aren't as good as some in the mud.
I've got Big Horns on my '10 Brute and Big Horn 2.0's on my 08. Both have been excellent and suited my needs well ....the only downside is that they never wear out! ...lol
I just picked up a set of Kenda Bearclaw HTR's about a month ago and I like them. 8 ply radial,run true to size,pretty aggressive for a trail tire and they ride smooth on hard pack.
I had bighorns on my old quad. I enjoyed them alot!
I'd go with the MOTO MTC's they'll out perform and outlast the Big Horn 2 to 1 not too mention they just look good.
KAWI RULES
Kenda Bounty Hunters here and love them - they wear good too,but are directional.I've rode on these tires flat,and off the bead, two times now,over rocky terrain,filled them back up,and they still keep kicking butt.Although I would like to try the Bighorn 2 or Grim Reapor tires.These are 14" x 8" wheels, 9" x 26" front and 11" x 26" rear.
my vote is for Big Horns, if they can run on my RZR XP and not get flats there tough will all the added weight of the SxS imho
moto MTC ! pretty deep, but close spaced tread pattern. they have nice side lugs too. very simmular to the Big Horns. i would recomend them for trail riding. another super tough long lasting tire is the Highlifter MST. a little more aggresive, but they ride better than you would think and they wont let you down.
+ Google Video
ERROR: If you can see this, then Google Video is down or you don't have Flash installed.
1 - 20 of 32 Posts
