1 - 14 of 14 Posts
I did this at the shop today, only took about 30 mins , 2 2'' 45's off of air box.......,2'' to 1 3/4'' reducer......., 22''of pipe, ......1 3/4 ''90 up .......,3''of pipe,.......1 3/4'' 90 to the center......,4'' of pipe,.......1 3/4 90 up through plastics in center:bigok:MIMB style:rockn:
nice work
Wilson Creek Riders
Hows tha bear run? My Buddy been wantin to do his, don't trust me ta go at.... His baby ya kno
Just curious, Why the scale down in pipe size also?
Runs fine, scaled down the pipe to clear the jug ,plus its only a 350 LOL
looking good. when you going to test it? :D
Tested only by sealing off the intake and choking it down . They will test it for me LOL, I figured if I tested it ,I would break it
Anyone done this on a 400 big bear yet?
Ill be doing this on a 2004 400 bb. what size pvc do i need and what size jetting do u think ill need to swap out? trying to do some research before i go at it thanks
i have a timerwolf 250 4wd, is it close to the same setup as the big bear?
If you use 1 1/2 inch pipe you will have to rejet it. You can put a reducer on the end of it an not rejet.
1 - 14 of 14 Posts
