1 - 20 of 210 Posts
Ok I have looked to find the answer, I am sure someone will say it has already been talked about on the site. What is the biggest size tires I can run on my 07 brute. I want to use my stock wheels. I am thinking skinnys for mud and my xtr's for trail use.
Bayou Boys Offroad
I have seen 30" mudlites on a 2008 750 Brute with stock wheels and 1.5" spacers, If your looking for skinny mud tires and keeping your XTR's for the trail I think you would be able to fit up to a 29.5x10 Outlaw.
Kajun Mud Slingers
I have 28s and have had no problems with no lift. I am now running a 2 inch lift just for the extra ground clearance.
I was thinking I would be safe at 28's so it sounds like I should be ok. After you get those mimb snorks you just get a strong desire to GO DEEP. Next thing you know I will be asking what the best lift is!!
Kajun Mud Slingers
:agreed: I know that feeling.
any one put 30's on an 08 with no lift? can it be done i was thinking some 30" zillas skinny wide combo proly on my SS wheels.
also does anyone have a pic of what the 9" zillas look like on some wheels
you will with my 30's with a 2in lift it was still close even though mine were 11 wide up front i dont think the 30 are gonna fit good with no lift now as for a 07 and down brute it may be done due to the suspension change in 08
yea i know the 08 are a lot lower. i have the aluminum products stick guards and it says they will not work with a lift has anyone tried to put a lift on when they had them?
Dirty White Boy
I put 27 -14 Mudlite XTR's on my 09 brute. They hit the front bumper when i ride hard. they actually tore it off
^^you running stock wheels when it hits? I'm running 28" mudlites and have never hit the front even on the softest setting and a winch and audio tube on the front
Bayou Boys Offroad
Here you go 08GreenBrute this is Debo Brute's Sig. He doesn't log on much anymore but you can shoot him a PM and get his attention if you want. He has the same a-arm guards you have and is running a 2'' Xtreme lift and 30's. He also ran the 30's for a while prior to adding the lift with only 1.5" spacers and stock wheels.
08 Brute 750
xtreme lift
30" mudlites on 212's
MIMB center snorkles
1.5" spacers on all 4
custom backrest
lil radio up front
Aluminum Products A-arm Guards
May the Force be with you!
i have had 30" mudlights and 29.5 laws on my STOCK 08 brute they both grab some plastic in the front but easy fix with a razor knife, the laws scrub no where else, the mmudlights with 2 people would scrub somewhere under the back fenders when i would romp on it
brutedaddy09 your not running a lift right
TX4PLAY thank you thats what i was looking for
I stickied this thread so we can all keep up with it for future reference & new people.
im runin 29.5 with no lift! but then i got a 2in lift
Wilson Creek Riders
Varies between SRA Bikes too.... And SRA wheels. Cos' the steel wheels are alot diff than the Aluminum wheels on the SRA's. Grrrrr, Darn Gas tank.
With the Aluminum wheels I had 28" cleared just fine, well not with steel wheels, Nope, ain't happenin':saevilw:
27 xtrs on 14 wheels would rub the back foot peg plastic with 2 people and no lift shocks in stock location on an 08. 29.5 outlaws with 2 inch extreme lift with 2 people will rub bottom black plastic on the front were the winch would go on tight off camber turns front shocks stock rear all the way down for soft ride on an 08. 750 brute im talking about.
move out my way
I ran 29.5 no lift never hit unless I was in a sharp turn in a ditch or somthing I did turn the springs all the way up to help that
1 - 20 of 210 Posts
