Hey guys Nice to meet all of you, I am also part of some other forums but I have heard great things about MIMB so I decided to join, and since i have a brute now i thought this would be a great place to be. So having problems with the new brute. It only has 114 miles on it. The guy I bought it off of was 55 years old and used it only to plow his 20 foot long driveway lol. I knew it was a great deal and thought the carbs just needed to be cleaned Its just not right whatever I do. I cleaned the carb, new gas, plugs, ect. The stock settings on my brute after I drilled out the plug was 1 1/2 turns out from light bottom. I took them out and cleaned them. Since I have gotten the brute it backfiring randomly at low speeds into the front carb then is fine all the way to wot. So Decided to try 2 turns out. This was alot better but bogged off the line then was full power. Some say it might be lean because of the bog off the line. If you could chime in on this, that would be great. Does anyone know their stock settings for the air/fuel screw for the brute 750. I live in nj by the coast, so altitude is not a problem. Very flat here. I would really like to ride my new machine and take a break from working on it. Thanks in advance again. It is all stock.
