Ordered it today, thanksJust replace the speed sensor. That should do it.
Remember...it's in the oil so either tip it way over to the left, be very fast...or drain the oil.Ordered it today, thanks
Yea I did a little research, I was bout to do a oil change before the next time I take it out so I’ll just do it all in one go, thanksRemember...it's in the oil so either tip it way over to the left, be very fast...or drain the oil.![]()
Was the broken speed sensor your problem? Im having a similar issue except mine won’t go into 4x4 I have a check engine light and an eps light while looking the bike over I noticed my speed sensor was in 2 pieces so I replaced it but on start up lights are still on and still no 4x4 please helpBroke my speed sensor on today’s ride the bike is stuck in 4wd and the check engine light is on. is this a result of the speed sensor or should I expect more issues the. Just the speed sensor. Thanks for any help in advance.
Yes, at least it worked for me. I was getting errors that the light bulbs from the headlights are burned, even though the bulbs were working correctly. I went to a car repair shop, and they said the sensor was broken. I accidentally broke the sensor on the right headlight when I installed the LED light bulbs I have t from https://www.vont.com/product/smart-strip-lights-led-strip-lights/. I am very happy that the problem was in the sensor, not something else because it is cheap and easy to replace.Just replace the speed sensor. That should do it.
