1 - 18 of 18 Posts
· Registered
I have a 2006 750 brute force that fires good on the front cylinder but the back cylinder only fires for a couple seconds then stops? What could it be?
· Registered
Discussion Starter · #5 ·
I have put new plugs switched coils over and the problem was still on the back cylinder it also has a new battery. what do you mean by water in the bowl?
· Super Moderator
When enough water gets into the carb bowl, it covers the jets and stops fuel flow,thus stops a cylinder from firing. Just drain them to be sure. The screws are like torx and are on the clutch cover side of each.
· Registered
Discussion Starter · #8 ·
I drained them and it didn't do anything?
· Registered
05 brute 750 I have checked the pulse coil its sending signal properly to cdi as front coil fires properly also checked buss connections and tried new cdi as it seemed to follow to that w tests. Theres only one pulse coil on this so both coils fire at same time everytime right? And swapped coils did not change. I am not new to this i have an atv and cycle repair shop for 10 years now n been wrenching on the same for 20+ years but this thing has me stumped. Seems it might be in ecm? Upon first turn of key i get proper spark on both after about foir seconds rear plug stops sparking. 2wd-4wd flashing back n forth also.
· Registered
Well if the pulse coil wasnt putting out enoigh to trigger both maybe or stator not putting out enough to charge both coils? But w a fully charged batt u would think it should fire both? Also now mine has stopped sparking on front and started only sparking on both upont first touching start button and release of start button. These machines are the worst i have ever worked on
1 - 18 of 18 Posts
