1 - 13 of 13 Posts
what would cause the fan to only come on for like 3 seconds,it ran hot and shutdown for about 20 minutes then when the motor cooled off it ran fine but the fan is not comming but a second or to and its gonna run hot again and i dont wont to blow the motor up.
might be the fan relay buggin out.
once i get the prairie fixed i am gonna start ont his problem
Whats wrong with the prairie ?And yes the relay is overloadin prob. from mud in the fan motor clean it out real good and should be fine
the radiator looked pretty clean and fan to.the fan would only come on for like 2 to 3seconds.
the dang ball joint came loose on the prairie lucky werent going that fast ,but may need new strut and tie rod we will see.
well,i got new ball jointa put in prairie,not a bad job.it is back up and going.then got to checking the brute and the relay under seat was bad.i replaced the relay with a 15 amp blade fuse inline and the fan is running like it should so no more overheating hopefully,but as soon as money gets better i am gonna put in a triple flow from high lifter.
i gave it heck after i replaced the relay and it worked great.
Replace that peice of [email protected]#% relay with a 15 amp blade fuse, and your problems will be over and done with. I have been through 2 relays with the same end result, they arn't worth a [email protected]#$. Save yourself some time and money, use the fuse before you blow a head gasket or worse, crack a block from running it to hot.
Thats what i did.luckily first time it ran hot it went to limp mode before it hurt it.but no more of that the fan is working great now.
Kajun Mud Slingers
Where exactly is the relay. I have the same problem. I will check the fan when i get home as i will relocate my rad but need to get my fan to work right.
The fan relay is under the seat kind of in the left front corner (sitting on the bike). It is a little grey box with a small green reset button on it. It should be wraped in a black rubber cover.
that's the fan breaker
the fan relay is all the way to the rear. 2 in the center its the one on the left.
the one on the right is fuel pump.
1 - 13 of 13 Posts
