I will update this 1st post as more info becomes available....
If you have LARGE Tires 30-32s and need more low end grunt to help turn them and relieve the stress on your clutch and eliminate belt slippage. This is the MOD many consider a must do. I have gathered the info from this board(from a thread Walker started) and have quoted people that provided the info.
Again this 1st post will get updated as new info becomes available.
These are the parts you need to order
1. Local GM dealer. Part# 1 #1052351 It's bright Yellow 1oz tube.
2. http://www.summitracing.com/parts/SUM-730000
Dial Indicator with a Magnetic base stand.
Here is the manual procedure to remove the bevel gears and set Lash.
Picture TIPS:
1. Click on thumbnail to make a bigger picture.
2. To Enlarge picture, Hold "Ctrl" key and scroll mouse or Hold "Ctrl" and use "+ or -" keys.
Pictures of what it looks like inside.
The Math:
Picture TIPS:
Gear Mesh Tooth Patternslinkage said:
The Math:
phreebsd said:
