Good deal. Thank ya sir! Seems like that would make the project a LOT more approachable. LOLYes it is, you are correct.
No splitting the case had mine out in half hour its easy. i found from my local dealer that they would get them for 80$ but they cant get teyrex parts because they dont deal them so told the other dealer i work with the price but alittle higher so thats the price they gave me. i will take measurements tomarrow on that tool i made and post it and thanx .:bigok:Correct me if I'm wrong, but according to the pics from the service manual it appears that this is doable without splitting the cases??? :thinking:
Really only a half hour?!?! Geez I would have thought it would have been quite a bit more labor intensive than that. Did you have to pull the motor to do it or was it possible w/ the motor still on the bike? How long did the whole job take all in all?No splitting the case had mine out in half hour its easy. i found from my local dealer that they would get them for 80$ but they cant get teyrex parts because they dont deal them so told the other dealer i work with the price but alittle higher so thats the price they gave me. i will take measurements tomarrow on that tool i made and post it and thanx .:bigok:
I didnt get the gears yet but thats the price he gave me. going to order soon but pulled the gears out to make tools. All u do is take off rear driveshaft and front take out the four bolts that hold it in and knock it out then pull left floor off un bolt there and its out easy but putting the gears back in and getting the backlash and tooth contact is going to be a different story not so hard but in and out to shim if you know what i mean.Really only a half hour?!?! Geez I would have thought it would have been quite a bit more labor intensive than that. Did you have to pull the motor to do it or was it possible w/ the motor still on the bike? How long did the whole job take all in all?
maxpower dont listen to everyone !!!! it works or people would be changing there;s back to stock..well according to some people on here all it will do is slow you down and there wont be any benefits to it
How much top speed does it kill? I have it all apart but wasnt sure after hearing from someone that its like rideing in low. But sick of going threw belts and could use more low end like when i get my 29.5"nators next week.maxpower dont listen to everyone !!!! it works or people would be changing there;s back to stock..
Have u got it in yet and if so wat diff does it makeBevel Gear the nut measurements aprox O.D of the nut is 44.78mm/1.763"
Slots are 5.12mm/.202" wide
across the flats is 40.74mm/1.604"
hope this helps a lil for those who want to build a tool vs the $ 270 kawie socket. I can write up how I made mine but I cheated I have a lathe and a mill with carbide tooling most don't. I don't know if it using machine tools would disquallify my tool for MIMB status. but my tool only cost me $18.00 and lil time
