1 - 6 of 6 Posts
· Registered
Any of the can am guys know if there is supposed to be a hose coming off the overflow on the battery. My battery is leaking acid all over my diff. I was just wondering if there is supposed to be a cap on it or a hose or something
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
· Registered
Both of mine have sealed batteries so dont know, but my guess is you probably filled yours up with water if its vented......lol I know you play in the stuff just from your avatar:D
· Registered
Yes I think I filled it up with water so every time it gets a lil shaken acidy water drips out and is keeping my diff.from getting stained but its also keeps peeling the paint off my axles. Do you think ot would be ok if I just sealed it or should I run a hose so.it leaks away front the bike
· Registered
^ submerging a vented acid-filled battery means you're going to be buying a new battery fairly soon anyway, but assuming it has a place for a vent hose to hook-up then yes that would be your best option until then.
· Registered
Discussion Starter · #5 ·
Ok thanks
Sent from my SAMSUNG-SGH-I997 using Xparent Purple Tapatalk 2
· Registered
I think my battery needs to be replaced on my outlander and was wondering if anyone has replaced the stock batt with a lithium batt? Or is it best to buy the same original batt?
1 - 6 of 6 Posts
