1 - 8 of 8 Posts
I have and 2011 800R xtp, It will turn over but not start, Now the dash will light up but no digital info is shown, the only thing the dash will do is blink the check engine light. And sometimes the dash will work and it will start. Any suggestions?
Check your battery cables. Make sure you got a good connection and no corrosion. And also check your electrical plugs. Might have a bad connection some where.
Thanks, I checked all my connection plugs and battery, I have that d.e.s.s. witch is supposed to be something with with the encoded key, Do you think it is possible that has something to do with it? It turns over strong
Double check the fuses. On my son's 08 outlander 800 xt the diodes in the fuse box were bad,could start by shorting the solonid and run. Be sure about the way diodes are in only work one way.
1 - 8 of 8 Posts
