1 - 2 of 2 Posts
2012 Canam Outlander 1000 Snorkel Notes:
You will need mechanical skill and proper tools to install this kit.
If any doubts, our shop would be happy to install. Contact our service dept.
Quality of snorkel depends on time and care of install, results will vary.
This kit relocates the Air and CVT Intake 12" higher than stock, and the CVT Exhaust 20" higher than stock.
It increases the Air intake diameter to 2", which results in no HP loss, from bends in snorkel.
Remove all burrs and stickers so they do not get sucked into airbox and CVT.
Test fit all pieces before final gluing.
Placing hand over finshed air intake with ATV at idle, is a good procedure for testing leaks on air intake only. ATV should stall out.
Review all pictures and pieces before installing.
Air Intake Pieces labeled YELLOW
CVT Intake Pieces labeled BLUE
CVT Exhaust Pieces labeled RED
Pieces fit in number order, 1 to 2, 2 to 3, 3 to 4, and so on.
Bench Pictures of Air,CVT intake and exhaust do not show proper angles, and are only to show proper order of fittings.
Cut Air Box Intake to 5" in length.
You will need to seal airbox lid, and drain with proper silicone.
Air Intake hole in pod cover is drilled with 2 1/2 hole saw.
1 - 2 of 2 Posts
