My 1991 Polaris Trail Boss 350L is leaking fuel from the carb overflow tube like a faucet. Does anyone know why and what I can do to fix this?
Sounds like your needlevalve/float is sticking. Trash under the needle valve is possible. For a quick fix, try tapping on the carb with a small wrench or something and see if it stops. To fix it for real you'll probably end up taking the carb off and cleaning it.
I had a Yamaha carb do the exact same thing, it ended up being the carb vent line stopped up.
Yep, sounds right. Been there,done that a couple times. I was lucky enough to just take the bottom of the carb off and spray it full of carb cleaner.
those old polaris 2 strokes vibrate so much that in time they wear the needle oblong because the tip of the needle is made of rubber and no longer make a seal. you will most likely have to get a new needle. i had to do this twice in the lifetime of my '91 trailboss(R.I.P.)
