Went out Friday night my baby broke.
Lost all battery power. Replaced battery with new (thinking the battery just shorted out cause it was orginal) but it drains very quickly and goes dead again.
Have foglamps, winch and recently installed hand warmers (may be related, but no problems until warmers installed). Will all disconnted, still have same problem.
Tested battery voltage at battery. Too low 11.6v.
Tested at alternator lead (as per manual) and have 60+v.
When she was acting up, even when key was turned back, the instrument panel stayed illuminated and headlights stayed on, but would not start until key turned ahead. Diconnected ignition switch, not change. Wiggled and checked a bunch of connectors and seemed when I played with the headlight/kill switch problem went away, but now I cannot duplicate problem. That problem went away, but charging problem still exists.
Took the regulator/rectifier to work today and preformed test as per manual, passes.
Any suggestions?
Any suggestions?
