1 - 5 of 5 Posts
have a 08 bf rode all night sat ran perfect woke up sun to ride wouldnt start checked filter, oil, wire connections and of course gas and no luck any suggestions???
ok first thing..
when you key on you hear the fuel pump?
did you pull plugs and check for spark?
try reseating the CDI and ecm connectors?
i have similar problem you are having. i had to unplug and replug every relay at the rear. finally it started and never had a problem since.
which one is the ecm connection
the smaller black box
fixed problem fuel pump fuse blown replaced it and started right up
1 - 5 of 5 Posts
