do i need to do this step on a brute force 750i fuel injected
i cood not find the 2 hoses
Remove protective box on front of air box and set aside, you will not need this.
There will be 2 hoses, run into a white canister, with a single hose on the other end,
these are your carb vents. Remove white canister, and attach the 2 vents using a
"T" and run the 3rd line up into the Pod thanks
thanks man
all you need to run is the radiator oveflow bottle vent tube and the gas tank vent
