This wont be the greatest of how-to but atleast it will give some kind of starting point.
First start of with drilling a hole in the side of the airbox. I used a street 90 to insert into the airbox, I had to trim off some of the 90 on the inside so that it would not interfere with the airfilter housing.
Finish product
list of materials for this is listed starting from airbox:
ALL 2" ABS
I used a 3" rubber 90 with the flanges trimmed off. I suggest trimming just the flanges off to start with then trim as needed from there as the 3" 90 arent cheap. you will want to trim the 90 down until it is approx a 45. You will have to trim untile you get it to fit like you want it. It will be a tight fit but it will fit.
Take a street 45 and insert the flanged end into the trimmed 3" 90
Parts listed from airbox:
Parts from bottom to top:
If anyone finds a mistake let me know and ill fix it. I do not want credit for this as i got ideas from several people to get this done.
Thanks to all who contributed in the links below
LINKS:
http://www.highlifter.com/forum/m_2910853/mpage_1/key_/tm.htm#2910853
http://www.highlifter.com/forum/m_2652909/mpage_1/tm.htm
http://www.highlifter.com/forum/m_2673046/mpage_1/key_robert7192/tm.htm#2673080
Finish product
ALL 2" ABS
- long turn 90 street
- short pipe so the coupling can be attached to the 90 to make taking airbox off easier.
- Rubber 2" Coupling
- Peice of pipe to get you up to where the upright will be. (Dont bother with the coupling that is right after the rubber coupling I screwed up and it was either buy a $2 coupling or another 5ft peice of pipe)
- short turn 90 (I had to cut i peice of pipe short enough that this part and the next was connected to get it to come out wher i wanted it)
- 2" rubber coupling
- upright of your choosing ( I used Pipe to another street 90)
- 3" rubber 90 trimmed to approx a 45
- street 45 (flanged end inserted into the rubber 90)
- street 90
- 22.5 joint this was necessary for mine to come out close to vertical but you may can get yours alligned better than me.
- small peice of pipe
- rubber 2" coupling
- then the upright of you choosing
- street 45
- pipe
- regular 45
- pipe
LINKS:
