For all you snorkeled Outlanders / Renegades....!
Make sure you also run your Gear Box breather hose up high with your snorkel. All to often folks don't mess with it due to it having a one way valve on the end.
Well.......its much like the Honda's one way valve on their older carburetored models.....it fails.
I'd highly suggest running the (highlighted in yellow) hose up high. It should have a dark black hose attached to it that drops over and is held to the side of the gear box (right side if you are sitting on the ATV) with a white or black one way valve on it.
Take that hose off and run the new longer hose up under the instrument panel and then reattach the one way valve to it. Problem solved.
