1 - 12 of 12 Posts
Anyone got the number off the seal itself,not the part number to buy it from kawi. I got a partial BH63502.Going to see if my company can cross reference these seals. We deal with lots of gear boxes and seals.
Discussion Starter #2
Anyone?
Im in the car and will see if i can get it for when i get home in about 20 mins
man i cant find jack.
I got my company to order some seals. When they come in I will let yall know how good they do. Man,they cost no were near what kawi sells them for.
Definatly interested on how they do, if they do better than the OEM seals, I would be interested in some of those seals.
If you get the part # off the seal, I can cross reference it.
Kawie does not make the seal itself, so the part number on it will/should be different than the OEM #.
When I did the seal under the secondary, I cross referenced it and used a Napa seal with no problems.
I have never had a prob using NAPA seals:bigok: I have seen them go through some severe stuff and not leak unless the seal is just ripped out
SKF seals, so good quality.
I can get you the number off a rear seal!
i will do that when i get home. I'm interested in seeing how other seals work.
Discussion Starter #11
Just found out my company cant get the same seal. We are a mm off. Here is the specs on the kawi seal. 62 ID by 81 OD.
Discussion Starter #12
Boy was I off on the seal number.Bought a new one today and got the right number off of it.BH6356E. NOK i guess is the maker.
1 - 12 of 12 Posts
