1 - 5 of 5 Posts
I was thinking about lifting my root force 6" and putting on 31 tires, would I need to change the gearing?
Super Moderator
Can't change the gearing...well you used to with a bevel kit but not sure they exist any more. The 6" lift kit will cost you in the 4,000-dollar range. Might be better off doing a 2" lift and staying with 30s. Many thousands less and issues, just some clutch work.
^^ What he said... Clutch springs at very least, and full clutch work is always an option as well.
You would absolutely need to change the gearing. The easiest way to lift AND change the gearing that I have found is portals. I'm not sure if they make a portal set for the Brute, but you can check. SuperATV.com As said before- many thousands of $$$$.
The 2 inch lift with some clutch work is the most economical way to go..
The six is doable. But wiil cost more money to do . if you got the cash
1 - 5 of 5 Posts
