1 - 3 of 3 Posts
Oil is leaking from the oil line in the clutch case .. already replaced o rings ..the bike runs for about 10 mins but then I open up the clutch case and there is oil all over again ... How do I get it to stop leaking ?
P.S There are no holes in the line itself
Guessing you are talking about one of the rigid lines; are you sure it is seated fully? New o-rings are pretty tight even when lubricated sometimes.
Super Moderator
Sometimes the line can get warped or split/crack. Sometimes as tight as the )-rings fit they can get cut or damaged on install. If you are 100% sure it's the line then I would replace it and/or the O-rings again. Do look ate the other seals and the intermediate cap as well.
1 - 3 of 3 Posts
