I have already been through several threads with similar issues. I was ridding this weekend came home washed it off. had a hard time starting her after a couple tries got it to catch rode for about 10 miles no problem at all backed her under the shed and now she won't start just turns over and won't catch or even try to crank....this is what I've done so far... checked both plugs got fire changed them out anyway.. pulled all fuses relays and edu from under seat and checked the connection... even pulled the fuel tank dumped all the fuel changed the filter on the pump verified that it was pumping when i turnt the ignition one and after hitting the starter button... took the roll over switch off and shook it real good hear the ball rattle inside and put it back on...i took off the air filter and you can see down to the top of the valve and can smell gas if you turn it over for a couple of seconds... sorry for the long post but i am at the end of my rope..ive only had this bike for a month or so and my first experience with kawasaki isn't good so far..Please Help.. also the fi light is flashing while I'm turning the bike over.. but goes away when i stop pushing the starter button..
