1 - 3 of 3 Posts
I have a 05 Brute force 750. I have snorkels hmf exhaust dynatek cdi.
I can put it in neutral and rev it to max rpm, put it in gear and slowly give it gas and it will go up to 30mph then max rpm nail it and rpm and 19 to 30 mph. It ran fine set for a few months then it started. Cleaned the carburetors same it’s jetted 155/160 or 160/165
Super Moderator
So what is it...155/16o or 160/165? The stocks were 152/158. With your stuff and a 3" snorkel you should go up 2 sizes but if you are using a 2"..well that's out the door. Still, probably has some partly blocked slow/pilot circuit so they will need some help.
Look at your plugs, and scope your pistons. More than a few have had problems with that cdi.
Plugs will help tell you if you need to adjust your jets.
1 - 3 of 3 Posts
