1 - 2 of 2 Posts
2005 650 brute force electrical problems. I try to start it and nothing, cluster goes out does not even try too turn over no clicking after letting off the starter button it will all light back up. Any help out there? I tried to read other forums but can't figure this site out
Super Moderator
That's an indication of a bad battery connection...either at the battery or the main fuse. Remove and clean the cables first. Also include the other ends of each cable...wich for the positive is at the starter solenoid and the ground...which is to the engine case, center, above the belt cover.
1 - 2 of 2 Posts
