1 - 9 of 9 Posts
Lord and Master
Anybody running these? I want a little stiffer spring in the back so I can run in the middle of the adjuster most of the time and crank it up when I am towing a trailer. Right now I am all the way up and it is way too light for the trailer. A small lift from these springs would be OK but I don't want to lift it much as we ride a lot of steep terrain in the foothills and mountains.
im running HL springs. they do provide a more firm ride no doubt.
they are designed to provide 100lb more lift than stock springs.
Lord and Master
That is probably about what I am looking for. Do they give any kind of a lift?
yep inch to 1.25 lift.
Lord and Master
Thanks guys. 1" lift should be fine, probably won't lose much stability on the steep.
Like a fool, i still climb all the same hills i used to.
Some are pretty steep
I aint scared of nothin:p
1 - 9 of 9 Posts
