1 - 10 of 10 Posts
I was riding my brute force today and it went into limp mode so i reset it and go riding and goes back into limp mode. I take the belt cover off and check the deflection and i could move the belt all the way to the middle and i need to tighten it could someone give me some help
Belt is adjusted by adding or removing shims.
Chances are you need a new belt if you have not replaced it recently & if you have that much deflection.
i jus replaced the belt a week ago
OEM belt?
yes
If you are popping belts almost everyride, is it the shim issue or could it be something else?
thanks for all of your responses the brute is up and running and soon great
1 - 10 of 10 Posts
