Does anyone know how to do the fan switch trick?? Pics would be great!!!
That seems like alot more work & wire running than just what I described.. having to run more wire. I think bypassing it would be much simpler & cleaner. Bu to each his own...You can use a three position switch to do what you are trying to do hook t-stat lead to top side, 12 v lead on bottom and hot wire for fan on center and you will be able to run fan when you like or let the t-stat take over depending on pos. of switch
its only one 12 v wire that is not already there you basicly just disconnect the hot wire from the fan connection run one side to the top and one to the bottom of the switch then put your 12v wire you ran to the center simple as that I do se the simplicity in your design and think i will change mineThat seems like alot more work & wire running than just what I described.. having to run more wire. I think bypassing it would be much simpler & cleaner. Bu to each his own...
