when i was looking at the pictures of the write up it looks like the catch can has a tilt to it is it suppose to, but then going down to another picture he uses a level, so im just wondering which is it.
also when im bringing the hose from the original air box port to the catch can what route should i take just right under the air. i ask because there is a pretty good slope if you go under the air box to catch can.
The bottom does slope so oil will slide back down the vent as it does with the YFZ setup. I routed the box line around the back of the airbox then around and up to the port.
then it goes bottum port on catch can goes to crank case and middle goes to air box and you cap off the top one, im pretty sure that is how it goes. thanks for your help.
Some people with high compression pistons find that the extra blowby creates enough extra crankcase pressure that that tube channels oil up and into the crankcase vent chamber, then up the tube...lots of it. Many have either taken it out or shortened it to be well above the normal oil level of the crankcase. People say it helps a lot. No one says it hurt anything. Having some Catch Can troubles? Another think that will help is either get one of VFJs return cam end caps and tie it into the can or port one of the rocker arm covers and use it as a return. That will also help vent Crankcase pressure. And be sure the final vent...the one that goes to the pod or the top of a snorkel has a filter on it..not just open.
This is a very detailed post made BF Freak from the Kawie Central forum. With his permission i am adding it to the MIMB site. he did a great write up on this mod.
where can I get this part from and will it work on my2014 brute force 750 with the 840 bore kit
At the time I was BF Freak before changing to NMKawierider. All the parts are listed in the write-up but you should know that much time has passed and we found out that all that wasn't necessary on any stock engine. All that was necessary was to add a second vent off either top end valve cover or one of VFJ's cam plug vents and "T" it into the existing crankcase vent line. Will that work for one with an 840BBK? I don't know but if the rings seal as well as stock, then I would think it would.
Probably the same way as I did on my 06..but in the end I re-routed the crankcase vent from the can to the original port on the air box and sealed-up the one I put on the side. Just remember the oil has to blow into the can, splatter on the sides and back, run down and back down that same line back to the crank case while the gasses go to the airbox.
