1 - 3 of 3 Posts
I have a 09 stock brute force 750i E.F.I used only for yard work and very little trail riding...I was plowing my drive way and my quad completely fell on its face so to speak... would not re-stat and the lights don’t work....but the dash works?? Any help would be much appreciated thanks!!
Sounds like a power failure. Start at the battery and start checking all cables and connections. Also, pull the fuse box...and work it onto it's side. Then pull every connection on the bottom looking for wet or corrosion. Also might load test the battery and check the charging system.
1 - 3 of 3 Posts
