alright i have beatmy head against the wall trying to sort this out.......ive pulled and cleaned the switch....pull the front actuator, tore apart and cleaned, lubed and reassembled. thought maybe i had the actuator outta orientation.....its in the operative angle range.....so i decide im gonna take it out for a spin.....stop....switch to 4wd after 1.5 rotations its shows 4wd on display but my front wheels arent pulling.....stop switch it back to 2wd and i get the 1sec flash intervals.....so one would say BINGO 4wd actuator is bad......but heres the twist....THE FRONT WHEELS ARE NOW PULLING WHILE IT FLASHES 2wd/4wd!!!!!!!!!!!!!!!!:261: try toggeling the switch.....no change. turn the bike off and you hear the 4wd actuator pull out to 2wd!!!! ive checked fuses....connections under the fuse box....cleaned with electrical contact cleaner....re-applied dielectric grease. only thing i havent done yet was pull the KEBC actuator. im thinking of just bypassing the whole durn thing!!!! wish me luck!!! if anyone else has had similar issues PLZ PLZ PLZ chime in!!!!
soory for the long ranting post!!
