41 - 51 of 51 Posts
im thinking maybe in need to do the reset procedure. because the 4x4 actuator has been disconnected for a while.
i have a manual but i don't see the procedure in there.
could someone help me with the steps????
Thanks,
so you think the belt light reset procedure would reset my actuator control box??
there's no reset on the ACM. the box will reset the actuator upon key off.
so what do you think would cause my brand new actuator not to work.
I didn't read the thread from beginning to end but you do know the bike has to be moving a little for the 4WD to engage?
i mean i didn't drive down the road with it but i did go at least 20 feet. forward and reverse.
when i have the actuator in my hand that is when i can see it twitch with the flip of the switch.
any more ideas??
The switch is either open or closed. Open for 4WD, closed for 2WD. Pretty simple really. I don't think it will cause the problems you describe but ya never know.
I have a 02 650 prairie and the lights don’t flash back and forth I have changed the switch on the handlebar and I checked the front actuator it worked faster in one direction and slower in the other the KEBC I can hear engaging at idle but it doesn’t make any noise when I turn the key off I have checked connections and fuses I don’t have a multi meter at the moment I have just got this bike and didn’t know what I was doing I bought a used actuator but what I thought was the problem is not and spending money that Maybe I shouldn’t have needed to spend I ran wires from the battery and from the black and red wires on the actuator and I touch them together one way to lock in 4x4 and then opposite to dis engage 4x4 to 2 wheel drive but don’t have a clue of what the problem could be. Any ideas
41 - 51 of 51 Posts
