1 - 8 of 8 Posts
When I bought my Brute the owner lived in Midland/Odessa area and never went mudding in it. So he decided to dril 1 and half inch holes into the airbox. He put 9 holes in it all together. Since I have had it I put a new airbox in it and put snorkels on it. I know its running rich cause it will back fire through the exhaust when I left off the throttle after having it about 3/4 to WOT. Thing will shoot flames out some times about 3-5 inches long. Haha... I know running rich really won't hurt anything but I want to change it. Is there really an thing that can happen when running rich other than fouled plugs? I have the Big Gun full exhaust and moose module. As it sits now what size jets should I look into buying? I just need a rough idea. Thanks for your time.
Lets Get It
Well we need to know what your doing this to first, so you can get a better answer!!!;) :)
Do you know if the other person ever rejetted?
Is it only when you let off the gas from wot?
Does it run good from idle to wot?
Gah sorry.. Its a 2005 Brute 750. Yes the owner rejetted it for the "open" airbox. Yes only does it when letting off from 3/4 or WOT.. Letting off from half throttle or less and its ok. Does it even more if I feather the throttle trying to get over/through something. Runs great from idle to WOT. Pulls very good. I like it alot better then my buddies Brute.
man shooting flames is a mod in itself. that's awsome!
Lets Get It
if it was running right with the 9-1 1/2" holes in air box, it probably has some big jets in it
I cant really give you a good ideal where to go with it being i have a 650 but I would say drop a couple/few sizes (depending on whats in it) in main jets and set the air/fuel screws to around 2 1/2, the air/fuel adjustment screw will take the popping out on deceleration, may have to adjust the needels, youll just have to play with it. Someone else might give you a better ideal what to run!!!
How or what snorkels did you put on it, the way you did it will make a difference
Try bigger snorkels, maybe.
to get the amount of needed for your current set up you would need about a 5 inch intake:haha: should be some info on here somewhere to get you jet numbers and carb settings
Here is a easy way to look at it....This is the exact thing I was told b a very good Tuner....Aaron Sporna.
1/8-1/4 throttle....is your pilot jet.
1/4-3/4 is your needle
3/4-WOT Main Jet
1 - 8 of 8 Posts
