Hello, I have a Kawasaki Brute Force 300 and I think my clutch belt is slipping. When I try to climb a hill or I try to hit the max speed when the throttle is half way, my rpms goes crazy. I don’t know if the belt or the primary clutch don’t work properly. What can I do to stop these kind of jumping rpms? At how many kilometers do I need to change the belt and primary clutch?
P.S. Sorry for my bad English :))
Start by inspecting the belt. If it looks good, check the belt tension/deflection. It could be that the belt has just stretched a little, and you need to remove a shim
from the secondary clutch to tighten it up. We have instructions in the clutching section above on how to do both.
Took my belt cover over and it looks like I have an oil leak somewhere. All over the clutch was oil. I cleaned the belt, primary and secondary clutch and it works again. Unfortunately I can’t find the oil leak.
