***Admin Edit*** The information in this thread pertains to 205-2011 kawi clutches.... 2012+ saw design changes and it's best to just call VJF (Vforce John). He's the best when it comes to kawi clutches.
(Update) Heres a link to the spring chart that phreebsd made using the below information.It's well done and easer to read.
MudInMyBlood Forums Kawasaki Clutch Spring Chart
OK i have taken the time to put together a spring rate chart. I have collected these numbers from many different places on the net. I have tried to cross reference the numbers the best i could with other sources to be as sure as i could they are right. I have not actually check any of these springs with a scale.This info has been collected from the internet only in this case. If you have actually tested one of these springs and know the info posted here is wrong please let me know and i will change it on the list.Any help is appreciated.
Some of these numbers have been rounded to the nearest whole so there may be small deferences but not much.
Since you see EPI and Dalton springs both listed in lbs and Kg i tried to list both to help clear up any confusion.
My hopes are that this chart will help some with understanding of how each springs compares to another.
Primary Spring
If you will notice EPI and Dalton use a slightly different load measurement for the middle number on the primary spring. EPI is listed at 2 1/4" while i read some were that Dalton is listed at 2" ......I could be wrong about this.If someone can clear it up it would be appreciated.
P700/BF650/KFX700 Stock Primary ---0-12-124 lb or 0-5.5-56 Kg
BF650i/BF750i Stock Primary---0-13-152 lb or 0-5.9-69 Kg
EPI Primary Springs
Load--lbs--2 1/2---2 1/4---1 1/4 -----------Kg---2 1/2---2 1/4---1 1/4
Pink------------0-24-160--------------------------0-11-73
Maroon---------1-35-170-----------------------0.5-15.9-77.2
Almond--------19-47-160-----------------------8.6-21.3-72.6
Bright Green---22-38-123-------------------------10-18-55
Gold-----------25-47-135----------------------11.3-21.3-61.2
Red------------35-54-140----------------------15.9-25-63.5
Orange---------75-88-140-----------------------34-40-63.5
White----------75-92-155-----------------------34-42-70.3
Yellow---------95-106-145---------------------43.1-48-65.8
Purple---------120-132-181---------------------54.4-60-82.6
^^WOW the purple is crazy stiff
Dalton Primary Springs
Load--lbs----2 1/2---2---1 1/4 --------Kg---2 1/2---2 ---1 1/4
Blue--------------3-60-155-------------------1-27-71
Plain White-------10-60-114-------------------5-27-52
Orange/Blue------25-75-167------------------11-34-76
Black/Orange-----56-91-157------------------26-41-71
Black/White------45-82-143-------------------21-37-65
Secondary Spring
P700/P650/BF650/KFX700 Stock Secondary 97 - 216 lb or 44.1- 98.2 kg
BF650i & BF750i Stock Secondary 79 - 244 lb or 35.9 - 110.9 kg
EPI Secondary Springs
lbs-----2-1/2 Load--1 1/4 Load-----Kgs---2 1/2Load----1 1/4 Load
Maroon------90--165------------------------40.82--74.84
HD Black----115--220------------------------52.16--99.79
Almond------140--250------------------------63.5--113.4
Green-------165--280------------------------74.84--127.01
Lime Green--200--325-------------------------90--146.25
Blue--------233--337-------------------------105.75--153
Red---------237--326-------------------------107.6--148
Yellow------271--382--------------------------123--173
Dalton Secondary Springs
lbs-----2-1/2 Load--1 1/4 Load-----Kgs---2 1/2Load-------1 1/4 Load
Plain Purple--112--227------------------------51--103
Aqua--------134--246------------------------61--112
Violet-------112--264------------------------51---120
This is the chart for VFJ springs straight from VFJ himself.
PRIMARIES
#1 is red/gray/purple
#2 is red/yellow/black
#3 is RED/White/Black
#4 is RED/Green/White
#5 is RED/BLUE
#6 is RED/orange or RED/gold the orange Paint can look yellowish, orange or even gold.
#7 is RED/Gray/yellow
secondaries
#1 Gray/white
#2 Orange/Purple
#3 Orange/silver
#4 Gray/Red
I hope this has been helpfull....MetalMan
MudInMyBlood.com:rockn:
Primary Spring
EPI Primary Springs
Secondary Spring
PRIMARIES
#5 is RED/BLUE
secondaries
#1 Gray/white
#2 Orange/Purple
#3 Orange/silver
#4 Gray/Red
