Just what it says. Anytime you have to replace something, just reply w/ what it was & the part numbers. Even if you replaced w/ a non-kawi part.
750i Seals
750i Fuel Pump
Radiator/Fan
Added by BigBlackRancher:
2010 Brute Front Suspension Parts
*Controller under the seat (Small Box, not the CDI) 21175-0216
*21176, sensor, speed
750i Seals
- Front Seal (engine side): 92049-1570
- Rear Seal (engine side): 92049-0095
- Front Seal (differential side): 92049-1573
- Rear Seal (differential side): 92049-0028
- Front Diff. Axle Seal: 92049-1534
750i Fuel Pump
- O RING ---------------- 670E5090
- PLATE ---------------- 13271-0980
- PUMP-FUEL ----------- 49040-0033
- TUBE-ASSY ----------- 51044-0041
- BOLT,FLANGED,5X11.5 - 92151-1754
Radiator/Fan
- Fan/Motor Assembly - 59502
- Radiator ------------ 39060
- Radiator Cap -------- 49085
- Frame -------------- 32160-0227
- Lower right a-arm --- 39007-0064
- front shock --------- 45014-0203-17D
- right floorboard ----- 34028-0055-6Z
