21 - 40 of 50 Posts
· Registered
Time to dive into the rear differential. Anyone know a rebuild kit worth using other than all Kawie OEM parts? Bearings, seals, bushings and wet brake disc's. Might as well jump in whilst replacing the inner boots.
· Registered
Well nobody could tell me of a decent kit but has anyone tried this one? NEVER mind I looked it up on All Balls and they do not show a rear diff kit. Thought it looked like a front diff kit!
· Registered
does anyone have the part number for the besarings that go in the left axle in the diff.
92049-1534 is for the right axle seal, 92049- 1536 is for the left axle
· Registered
hey fl750mudder, how did you know which connecting rod bearings to buy, i talked to a local dealer and he says that kawaski makes three different sizes (green 92028-1961, yellow 92028-1962, brown 92028-1961) he said that you have to buy all three sets and install the ones that fit. i just ordered crank and rods but didnt want to order the bearings till i got those in hand. any help would be appreciated
· Premium Member
Look on the Electrical tab, on the ignition system section. 21176, sensor, speed
It wasn't easy to find, took me about 10 minutes.
· Registered
here is the exhaust gasket used for a muzzy pro exhaust:
GASKET EXHAUST FLANGE HEAD (STEEL) 1200CC-1600CC UP TO 1975 111-251-261B
# VWP-111-251-261B
NEW PART #
the clips (U nuts) that hold the plastic on and foot guards. these can be bought at NAPA and use the stock flat philip bolts (M6-1.0 screw size)
part # 665-3291
comes in a pack of 6
· Registered
aparentlly im a da cause i order the wrong seal for the right side of the front diff.
so i was wondering if this is for both sides Front Diff. Axle Seal: 92049-1534
· Registered
There are two different sized seals for the front axles where they enter the diff. that part number is for the right hand side axle. the part number for the left is 92049-1536.
· Registered
Has anybody figured out the rear engine seal part number I've thru all diagrams and found nothin
· Registered
Just what it says. Anytime you have to replace something, just reply w/ what it was & the part numbers. Even if you replaced w/ a non-kawi part.
750i Seals
  • Front Seal (engine side): 92049-1570
  • Rear Seal (engine side): 92049-0095
  • Front Seal (differential side): 92049-1573
  • Rear Seal (differential side): 92049-0028
  • Front Diff. Axle Seal: 92049-1534
750i Fuel Pump
  • O RING ---------------- 670E5090
  • PLATE ---------------- 13271-0980
  • PUMP-FUEL ----------- 49040-0033
  • TUBE-ASSY ----------- 51044-0041
  • BOLT,FLANGED,5X11.5 - 92151-1754
Radiator/Fan
  • Fan/Motor Assembly - 59502
  • Radiator ------------ 39060
  • Radiator Cap -------- 49085
Added by BigBlackRancher:
2010 Brute Front Suspension Parts
  • Frame -------------- 32160-0227
  • Lower right a-arm --- 39007-0064
  • front shock --------- 45014-0203-17D
  • right floorboard ----- 34028-0055-6Z
*Controller under the seat (Small Box, not the CDI) 21175-0216
*21176, sensor, speed
the part number for the rear and main seals engine side where are these parts found? they from dealer or other aftermarket websites? or a certain website let me know! first two brutes and one already needs it I'm a old can am lover converted to brutes! thanks!
· Administrator
Discussion Starter · #39 ·
Those are OEM Kawasaki part numbers.
Posted via TapaTalk for iPhone5
· Registered
anyone have a recommended place to get the front and rear main seals? haven't had much luck finding a parts website or anywhere that has them. other then dealer which says over a week to order.... also spark plug wires where to get those as well. and any websites y'all have had good luck on ordering please let me know thanks!!!
21 - 40 of 50 Posts
