1 - 2 of 2 Posts
Hi My name is Tasos and I am from GREECE
I am a Mechanic
I am working with one 2009 LTA 750i trying to fix a problem
Engine dies when the push the handlbar just a litle in low spead maybe under 35 to 40 kilometers
At 5 to 15kil the engine dies and blocks the tires
Oner 15kil to 35 engine dies and start again
same thing happens and when the speed is zero...
Over 40 kil evrything works property...
I replace EPS control unit after service manual chek following trobel shooting Line and resolts same
problem cod true Suzuki diagostic System SDS is TDC C1122 check and eraesed
Tork sensor checked
Speed sensor checked
Engine speed check and replased with other good one
Problem is still there ...eny idea....
or someone with same problem???
Thank you
Is there a ground wire to ground the handlebars?? Or maybe the handlebars are pinching a wire to the kill switch when you push on them...
1 - 2 of 2 Posts
