1 - 20 of 22 Posts
my buddys got a kodiak 400 it is bogging out wen he punchis the gass and it stalls out
he did sink it in water we did oil change cled carb and air fiter
mods MUFFLER STACK . snorkel
sounds like its flooding.
so u had snork on before and it was running fine before it was sunk?
ever sins we snorked it i think
i think it is flooding how wood we stop it
Are you saying that it won't get passed idle at all without stalling? Try to rev it up with the choke on. If this works it sounds like you still have water in the carb. Drain the bowl and see if it helps.
i clend carb out
it runs but bogging out and rev it up but lot of the time it is bogging wen full gass maby i make video
If its working some passed idle then it may not be water but just a piece of trash in the carb. I've seen carbs get 3 cleanings before they started working correctly again. It doesn't take but a tiny piece of grit to stop one up. Is it idling fine?
yes it is idling fine
my guess is you're going to have to clean it again
Discussion Starter #12
yes it did start doing it when he snorkeled it?
you will likely have to rejet.
To know which way (i suspect your are going to have to go down in jet size)
partially cover the snorkel with your hand and see if it revs any better. if so, you are lean and u need more fuel.
if it makes it worse you need more air. You guys used 1.5" tubing im guessing?
Discussion Starter #14
[ame="http://s8.photobucket.com/albums/a34/scarcrow/?action=view&current=MOV00707.flv"]
[/ame]
Discussion Starter #15
2 inch tubing
2" inch is more than enough.
does it backfire at all? what happens when you pull the choke when u try to rev it?
or put your hand partially over the intake snork..?
Discussion Starter #17
wen hand is partially over the intake snork runns bit beter
no backfire
Discussion Starter #19
how to fix it form running Lean
correct way - rejet
quick way - get reducer for the end of the snork.
1 - 20 of 22 Posts
