81 - 100 of 105 Posts
Ok let me explain something as I have been doing this for years also and have some of these products such as spring spacers....technically they do NOT lift the bike, I will put it in simple numbers so people understand.... it works as a factory bike sits just say at 4in well then when u sit on bike it goes to 3in now with springs spacers your bike may sit at 5in when not on it and once you sit on it it goes back to say 3-4in therefore being back to where you started really as it stiffens the load rating, as was said already...so really yes you get a bit of a tiny lift when not on bike but what good does that do cuz only time you need clearance is when riding, hopefully this can be understood
Yes!
Sippin cold beer and going deep!!!!
Hahahahhahaha. P people like this crack me up with the spring spacer lift. All u did cat was take out bike sag. But if u wanna put a 2" lift on top of the spring spacers u better call turner ad get u an hd u joint. Ur stock will be in a bind and eventually break. But u will prolly prove me wrong on this like u are trying to do with p. but we have been doing this for Years. We know what goes down when u do something with a bike. Js. But always remember young one, spacers don't give lift they take out bike sag and make bike ride like a tank!
x2 u bro all the spacer will do is max the shock back out because u cannot extend the shock more then it is all u will do is make the spring stiffer to beable to take more weight
I have 26'' Mudlites on my '01 Rancher 4x4, could I put 28''s on it with no GR??
Discussion Starter #90
Something light like a 28" Zilla would probably do fine.
Discussion Starter #92
I'd say no.
i say no since my bro in law had 28/12 backs scrub on the back on his 500 rubicon
Would a 23% or 39% gear reduction be enough to turn 30' Silverbacks or 29.5 Outlaws?
Discussion Starter #95
There's are threads for that. Please search. This is a thread about what tires fit STOCK.
Posted via TapaTalk for iPhone5
Haven't posted in a while, but figured I'd add I recently put 27x10 edls on a 06 rancher 350 using IRS wheels and 2 spacers on the rear. No rubbing at all with no lift.
100 things to do and wasting time on Tapatalk!!!
---------- Post added at 09:43 PM ---------- Previous post was at 09:42 PM ----------
Is this honda completely stock?
I'd imagine so, I have 28x9x14 Zillas on my 420 auto and they fit with no issue.
