1 - 20 of 35 Posts
i got 28" backs on my rinny with brgr and hl 2"
got some with my edls on
i got the 2inch lift trimmed my back plastics a little and i fit 28inch edls
Thread for Lifted Honda's with large tires (What fits/What rubs)
Post 'em up here
  • How Much Lift & What brand
  • Brand & Size of tire
  • Stock offset, wide offset, or stock with spacers
  • Any trimming done
  • Do they rub and if so, where
2008 honda rincon 2" extreme lift with highlifter springs and spring spacers standard offset 28x10x12 silverbacks trimmed lower mud flap on front does not rub now.
05 HONDA RINCON
TRD pipe, programmer
K/N, snorkeld
6" gorilla lift (bracket)
12x7 rear sra rims, vinson 161 black
27x12x12 vampires
04 Foreman 450 2" extreme with 28x10x12 front and 28x12x12 rears with no rubbing
420 rancher at irs
i got 31 outlaws skinnys
gorillastage 1 lift and spring spacers = 3.5 inches worth of lift
had to trim the rear floor boads and the front floor board suport
'07 Rubicon
29.5 s/w combo outlaws
2" HL lift
trimmed mudflaps quite a bit
still rubs on the metal bars which support the foot wells (in the front), when i lock out the steering
2004 Honda 350 Rancher
29.5 skinny laws all round on stock offset rims
2in lift, Lift Springs, STI lift springs (same as highlifter just better price)
As far as rubbing i had to bend in the front fender support to fully turn. On the rear I just had to trim a good bit off of the black plastic fender toward the bottom. I also pushed the supports forward that run under the rear floor boards and welded them there. I did this cause at about 20mph it would cause the tire to expand just enough to rub.
^^thats mike hydes old rancher. its on roids!
'07 Rubicon
2" HL lift
highlifter makes a bracket that deletes those stupid metal bars and supports the footwells underneath to the frame. its on the HL site, kinda pricey tho.
29.5 outlaw 2 skinnies w/ a 3" streched swingarm custom 3" lift, and rear 1.5" spacers, also removed front fender bracket and no trimming or rubbing
420 on 30s
Got my rancher on 30 xxls lift n springs n only rubs a little on floor boards support bar
06 350 rancher, 28 sw silverbacks with hl 2 lift. Trying to decide what I need to get 30 under it. It did not rub at all until I added wheel spacers all around.
Swing arm extension?
I don't know about the front end though. You may have to make custom floorboards. I'm gonna try that myself. I'm running 28" mayhems on mine, and they hit the back of the floorboard till I trimmed them.
Yea, that would be the ideal thing. Extended swing arm a custome a arms for the front. Not sure if I want to tackle it or not.
1 - 20 of 35 Posts
