I have a 2013 Brute Force 750i EPS and this bike has ran great until recently. It goes into limp mode after driving 100 ft or so. I had a aftermarket belt on the bike and was told that was the issue so replaced it with the OEM belt reset the code same issue, I was then told a deflection check it and it is good. Then was told a bad switch do I bypassed the 2 pin and just connected it back to itself so it does not break the connection but still having the same issue. I was told if I have something plugged into the cig it could cause a issue so unplugged that still same issue I am at a lose any help would be great.
Thanks guys in advance.
