So i got this 06 brute force 750 its been misfiring alot when i give it gas a it miss fires a little when its on neutral i cleaned the carbs last night with carb cleaner and it still didnt fix the issue Need help!
Super Moderator
Many things to consider. Have you set the valve lash recently? How's the system and battery voltage? If your 06 was built before November 2005, it may have the buss connectors. Has this been addressed? The carb boots on all the 05s-07s tended to crack at or under the head-side clamp. Has this been looked at? How about the fuel pressure and volume? How old are the plugs? Hows the compression? Have you tested the pulse coil to see if it has a problem? So you see..there are a few things that need checked-off the list.
Does a 2005 Kawasaki Brute Force 750 have a fuel pump?
