1 - 12 of 12 Posts
ok this should be the same on all Prairie and BF on the right hand side of the motor on the bottom towards the rear there is a 3 wire connector that plugs in to a sensor or something there (i'll try to a pic of the part up soon) mine got busted all to pieces right at the connector. the sensor or whatever it is, is held to the side of the engine by one 8mm bolt. can someone tell me what this part is or does. Thanks!
sounds like the speed sensor to me!
Discussion Starter #6 (Edited)
Is this the speed sensor ?
ok i found out this is the speed sensor part # 21176 and is the same on prairie and brute force. so now where would be the place to get one the cheapest
how about bikebandit.com, thats where I buy all my oem parts from, cheapest place i've found also.
they had it on there for 72.00 but i found it on babbittsonline.com for 58.00
Babbittsonline has the cheapest prices, but they rape you on the shipping.
Maybe Bootlegger could hook you up....worth a shot.
1 - 12 of 12 Posts
