1 - 9 of 9 Posts
Well my buddy brought is 05 to the house lastnight and it was in need of some TLC. I really felt bad for it... This is what it needed
rear wheel bearing
rear cv boot
oil/filter change
air filter
diffs changed
Spark plugs
Wouldnt stay in reverse
Heres why I felt bad for it - Come to find out this bike has 1826 miles on it with around 300 hours and this was its first service - yep thats right - never had an oil change or anything done to it other than fixing a few things were someone t-boned him after he first got it.
Well he got to the house around 5:45 - first I had to pressure wash it cause it would have been **** to work on with all the mud that had been one it from probably the last year - got the under carage clean so i could at least see the bolts. GOt it pulled into the shop - started on the shift linkage - no problem what so ever - got that done. THen went to the wheel bearing - started breaking it down well needless to say it took a cheater bar to break the bolts loose on the hub assy - then as i attempted to take the hub off - I ended up pulling the cv out of the diff - yep the bearing was so far gone that it acted as it welded itself to the axle so i had to beat that off - then the fun started - old bearing was a pain in the *** to get out - I guess u get the jest of it - I finally got in the bed around 1 am this morning and man you talking about a headache today.... I didnt think i drank that much last night but I must have...
After all of this - u'll be glad to know this brute is back to good standings well with the exception of the rear header pipe has about an inch and half crack in it - and the tabs have been welded. So now I've got to find him a new stock exhaust - cut the old one out from under it and put a new one on it. Oh yeah and do the buss connector fix on it. So still some to do but right now - its back to running condition.
It just amazes me how these things will hold up - i would have dang sure figured that break in oil with over 1800 would have already caused some premature failures...
sorry for the long thread
I feel sorry for it too ;( I hate to see a neglected brute. That does show it can stand up to some abuse though.
I have my stock exhaust. not sure how much it cost to ship it.
got my stock exhaust too if you need it let me know ...
Sounds like my brother and his Honda. 2 years old now and 2 oil changes only.
That's it. Wheels never been off, brake never inspected, fluids never changed. His time will come, but the crappy part is I'll be the one fixing it.
I have also got the full factory exhaust and a HMF Utilty slip-on for a 2008 650 SRA, if any of that helps you, just let me know and we can go from there.
KAJUN MUD SLINGERS
to much neglect for one bike
1 - 9 of 9 Posts
